baileyashley1989
- Sep 19, 2012
- 2
- 0
how to i post a thread??? i can not figure out how... and i really have a quesstion to ask and needs to be answered...
gabbek said:Can you upgrade to a newer version without wipe?
I have no Google account after doing it.
How should we upgrade?
Thanks for your info I finally got the tablet ui to work![]()
are u complety sure that it was the kernel? (e.g. did u tried the stock rom with the an older kernel? or vice versa?)
dzoking: i want to say that, it boots at 998 mhz, if u dont change it with app it stays at 998 mhz, that's why i said go to recoverymode and delete /data/data/*setcpu* folder if u checked the 'set on boot' option (or whatever app did u used)
whell its not boot at 998 ,i try and that version from 18.9. i wipe all including all apps and flash fresh and tru 50 times to get to settigs screen and finaly got there and it sad in performance menu that is 1113 ,then after 50 more restarts i instaled setcpu and lower fq to 1030 and it all worked well for hours until i decide to reboot..and offcourse it did not want to boot because it boots on 1113 and then when setcpu is loaded on startup it lowers to 1030 but it restarts before that in 9 of 10 times..
You maybe have some newer cpy then mine so it work whell for you ,my samsung galagy player is same on 1 ghz but i use it on 1.5 ghz no problem with just little more voltage. If you have time just compile me a kernel with max cpy of 1.03 or 1.05.
Thanks but no luck ,tryed both but they all stuck on Ideos startup screen so i definetly giving up of overclockingcould u try this? Goo.im Downloads - Browsing cm10_testing (just with fastboot boot boot.img)
edit.: boot2.img limits the freq in init.rc on boot
ei guys can u help me how can i install this rom in my s7 slim im noob here thanks
