myfishbear
- Nov 12, 2012
- 118
- 50
- Thread starter
- #166
Yep, if you try to manually sync calendar and some other google services it says "unfortunately, the process com.googleprocess.gapps has stopped".
I fixed this by flashing in gapps-ics20120429-signed.zip. You can't flash it over installed ROM with user data. It will have to be a clean install. back up anything you can't afford to loose.
Fix Calendar
put gapps-ics20120429-signed.zip (the one for CyanogenMod 9.0.x) on you SD card from here Goo.im Downloads - Browsing gapps
boot into custom recovery mode factory data reset and then wipe cache
instal zip from SD
Flash the ROM for your device
Right after ROM installs (before booting to system) flash gapps-ics20120429-signed.zip
After booting to system (and connecting wifi) I went into system settings>accounts&sync then select add account top right corner then choose Google. My calendar, gmail, contacts sync perfectly and Google market updates.
Google Chrome crash is because the DPI needs to be 160. Goto market and get app "resolution change / Density" it worked best of a few I tried https://play.google.com/store/apps/...wsMSwxLDEsImNvbS5tYXJ1dGlhbi5kcGljaGFuZ2VyIl0.
If there is to be any ROM updates could please reset default DPI to 160? but manually changing DPI it is easy enough.
both incorporated in v2.1
-new version check op
