maybe you shouldn't try this i literally told you every step. you are letting windows pick the driver you have to specify it with the have disk featureUnder my Device Manager it is listed as just "Android" and under properties it says "The drivers for this device are not installed(code 18)." Yet, when I point it to the google adb USB drivers folder it says "Windows could not find software for your device."
Ok I have the rom successfully up and running on my 911. However, the touch screen is not responding. Any idea on what went wrong?
Did you make a backup before flashing the new rom?
put the file in /sdcard/dump/Ok. So I have been working on this a few hours now, and I am lost. I was able to reflash it with livesuit and pull my bootloader.img. I flashed the d2 rom back to the device, and now I am confused on how to load the stock bootloader.img. Please help me? Thanks
then in adb try
adb shell cat /sdcard/dump/bootloader.img > /dev/block/nanda
