[ROM] EPAD 256M and 128M 1.9_88 rooted v0.3 WORKING MARKET FROM FLASH
What if when i updated, and turn on and waiting, waiting, after all it say "Program stopped working" or anything like this, what can i do now? i try other ROM too but same problem.
What was your original ROM Build? You'll need to go back to that one.
I don't know exactly what was the original build but i know it was with Android 1.6... Maybe 2.xxx but im not sure.
Well I've found the ODM Build if you look under Extreme Warning you'll find the link. I am hosting that link so no delay to get it. I goal is to help our members here!
Hi,
I have a device whit the following settings:
Memory Size: 256mb
Model number: generic
Firmware version: 1.6
Kernel Version: 2.6.29-00236-g4f8dbbb-dirty
Build Number: 1.9
Charge light: Red
Display: 7"
Some pics:
http: //img594.imageshack.us/img594/8148/img4269u .jpg
http: //img19.imageshack.us/img19/3125/img4270f .jpg
I've readed a post in forum that advices the ROM of this post for a device whit settings approximately equal mine, being the difference the Build Number (1.9 is mine, and 1.74 the one I readed).
So, my question is, can I use this ROM for my advice?
Thank you and sorry for my english.
Ornellas.
same ...this can use with this tablet??
Hi,
Memory Size: 256mb
Build Number: 1.9
Charge light: Red
Display: 7"
Some pics:
Ornellas.
same...are this rom ..match with this tablet??
Hi, I bought one M002 from Pandawill and I would like to know if this firmware works in m002 from pandawill. And how do I install this firmware? Just copy the script folder to the sdcard root and restart m002? Another thing: If I can't put this firmware in the m002 from pandawill how can I root it? I am running the firmware M002 Plus from slatedroid and tried z4root, Universal root and I can't get to root the device.
Thanks for all help.
Hi
Another Noobie, trying to improve performance of my tablet. I think it's a 7' flytouch form the pictures. Quick system info shows processor as ARM926EJ-S rev5 (v5l) 174.48Mhz. Is this the same as WM8505?
Firmware version 1.6 , 128 MB and kernel 2.6.29-0236-g4f8dbbb-dirty.
When I boot I see WMT2.0.1-105
Does this 1.988 v0.3k upgrade work on this tablet?
how do you flash the epad and install roms ? i'm new at this and just received the epad it acually says mid on box what to install roms updates ?
Hi! Why I can't install this firmware on my device? My device like in this post http://www.androidtablets.net/forum...model-device-2-6-29-00236-g4f8dbbb-dirty.html, but full black. The original ROM installed on my device was Windows CE. I installed many firmware on Android. In most cases something was wrong. I think this firmware go with my device. But installation process freeze on first screen, where written Android, kernel and SDK versions. I don't know what should I do. Thanks for any help and sorry for my bad english. Good luck!
Hi! All is fine! I downloaded Android with SDK 1.7.1 and installed this in my device! After that I installed firmware from this post (1.9.8) and all is ok! All working! Thank you very much!
i really need help pls.. my apad doesnt have a connect to on the settings-application menu... i cant get the root.. advice pls
how do i install this please some one help
im willing to donate on paypal
download the file
unzip it to your computer
copy the entire script folder into your sd card
boot up your device and the update will run automatically
once update completed, the system will prompt you to remove your sd card
reboot and you are done
