I had the same problem with wifi tethering with my Droid X, it made it real annoying when I was listen to say Pandora or Slacker Radio in my truck with the S7 and it would drop the wifi. Well I switched to Barnacle Wifi Tether and I had to replace the Wpa Supplicant file in system/bin to see ad-hoc networks and it doesnt dropped at all and its actually stronger than before and it still connects to my home wifi too
I upgraded 2.1 to 2.2 on a Telstra T-Touch and all seems to work apart from the email program which stops without being able to fetch mail from the Internet provider.
It says "The email (process com.android.email) has stopped unexpectedly. Try again"
I upgraded 3 times, once with another download but the problem persists.
Gmail works as does retrieving the same mail over the web.
Google suggests it is a common Android problem solved by clearing the email data cache, but that does not work for me.
One user suggested clearing all mail from all machines, particularly Australian mail, as the solution.
Being an Australian makes that a tall order.
PS Can you unlock this tablet and what does "rooting" do for you?
I bought the tablet cheap in BigW 2 daqys ago as a customer return not knowing it was completely locked to the previous customer and he had pilfered the sd card and usb cable.
I have ordered a micro usb cable hoping that will fit.
Google research suggested it was a "Dog" but I disagree.
I find it a bit chunky but considering it is Chinese home grown gear it runs really well especially with this new firmware.
OK, now that the initial flush of success has faded a bit...
I thought it might help to add some comments about my install experience, to add to the behavioral database.
I have a Best Buy unit, and when I started the S7 up after installing the SD card with the update folder, it just booted up totally normally. Hmmmm... checksum was good... Finally, I decided to remove the battery and charger cable, and try again. This time, I got the progress bar once I had re-installed the battery & charger, and re-started the S7. I was waiting for the "OK" as the progress bar reached the end, but then the screen blanked momentarily, and the progress bar appeared again. I waited more anxious minutes, then got the "OK" indication. I pulled out the battery & charger, re-installed, started up again, got the progress bar, then the beautiful "IDEOS" screen.
So, I think that we need to make clear that the all sources of power must be removed before the initial boot with the SD update card.
At this point, I have it rooted with SOC, I re-installed Titanium & restored my apps, and it's working very well. I had an odd situation last night where the menu button would not work in the home screen until I had started Titanium, but that seems to have fixed itself this morning. I installed the Flash 10.1 apk, and have had some good success with some sites, but Netflix and Hulu are still no-go. I have Playon, and that does seem to work OK, but it requires a desktop running the Playon software, so it's not the ideal solution.
Please Hulu and Netflix - figure out a way to give us a native Android app!
I have a SIM card from centennial wireless (a regional carrier bought out by ATT) with unlimited data. Like I said...A-GPS isn't working (unless it's now automated and you can't access it as a user), EDGE data is spotty and won't keep a connection (it's the OS not the network...I could stream pandora on the previous firmware...can't on 2.2), won't root with SOC (either method), GPS takes at least 10 minutes to get going without A-GPS, and the bluetooth/wifi will randomly re-enable after being disabled. I'm going to try and re-flash and format both the internal and external SD cards. Hopefully it will fix the problems. Here's hoping.
Im talking about my droid x tethering to the s7, it was dropping the wifi tether under the normal wifi tethering (I guess its a problem with the Droid X or Android Motorla PHones for that matter) so I switched to barnacle tether to use ad hoc instead... if you look at post #53 thats the one I used even though its for a samsung phone it works perfect for the s7 I havent had any problems and it still connects to my home wifi network fine.....Are you using wifi tethering with the updated 2.2? If so, where did you get the Wpa Supplicant file that works for ADhoc networks?
Thanks,
Jeff
I'm not having problems with the POP account(either 2.1 or 2.2). Your error looks more like a device issue rather than an email account issue(but not well enough versed in android OS).
I take that your WiFI router isn't blocking the port?
The Telstra device is prepaid so I think that it's carrier locked for a year or you have to pay for the network unlock code.
Rooting the device gives you system access, so removing the carrier apps, running apps that require system level access nothing to do with the network lock.
any micro usb cable should be OK, I don't recall whether or not mine had one in the box or not to begin with?
I would probably have described it as solid rather than chunky as the dimensions aren't disimilar to other 7" devices but it is quite heavy in comparison.
