How we can root it
Sent from my IDEOS S7 2.2 using Android Tablet Forum
What are you using your sim card from your phone?ATT or Tmoible... I myself just spent an hr creating a mount for my truck (08 Nissan Titan) and I tether with my droid x I have unlimited data might as well use it haha... it sounds like your having problems...I am really surpised that this went so smooth on mine with no problems just like before cept with flash and o/c to 998
I believe that was one of the negatives of Froyo - The market does more compatibility enforcement, and sometimes does so in a stupid manner. Things that can make a difference:Hello,
My upgrade went very well following all the great instructions in this forum! Thanks to everyone!
However, I have noticed one unexpected problem and would like to know if anyone else has experienced it.
I set up my google account for email and android market access (the same one as pre-update) and I had purchased a few apps. SOME of the apps are available to download, but SOME are not.
From the Android Market website, it says these apps are now not compatible with this tablet. Weird right? The tablet shows 2.2.2, and the minimum requirements listed for the missing apps range from 1.6 to 2.1.
Any ideas?
Hello,
Any ideas?
I haven't flashed yet but I have a general question about SOC: does using it require adb to be installed separately? Nowhere does it mention that adb is needed yet I see several references to it here. Is adb packaged with SOC?
OK, über Rookie here... Is it necessary to Root the S7 before this upgrade is performed OR after it is done? I have not done that and really have no need to do so unless it is required for the upgrade.
I have one paid for app - Graffiti Pro - that I hope to back up. Can anyone tell me where to look for it? I have the Rhythm Software File Manager installed which I think is letting me see the hidden files, so I think I should be able to copy that app to my removable SDCard (I will use a different card for the upgrade). I do not have any other files that I feel the need to backup. This is a still fairly fresh out of the box S7.
Will the upgrade include all of the apps that were preinstalled out of the box?
Best Buy S7-104 2 Cameras
Build number S7V100R001C28B010
Thank you!
My method was via Titanium Backup, In my case restored everything so would recommend this although I have been told that Mybackup is also very good.
Since it's a flash doesn't need to be a pre-rooted OS.
Rooting the device is post flash
Hello,
Any ideas?
