I can find anywhere in the superuser app that can disable su rights in the terminal emulator. any ideas?
I have tried that but it still not working. What emulator are you using?
It is not prompting me to approve the root access. I checked an SuperUser is running its just not asking me to approve it I am using Terminal Emulator version 22. Do you think i need to reinstall the SuperUser app?
other apps that need SU are working fine. I will see if i can find another terminal app and give that a try.
I agree with tdaly001 i want to encourage you to keep working on this.
l_n and jeffc83 i was able to get the su comand but i had to use a crappy terminal emulator. the one i was using was the one you suggested. any ideas on how to get that one to work again. I cant find a white list in superUser to add it to.
