Set CPU is probably not going to play well with the Kyros right now because the stock kernel (which this rom is based on) is not set up for overclocking. That could be part of your issue. Once we get a custom kernel it can be set up for overclocking
umm ya i know we cant overclock yet you do know you can still use setcpu to set custom speeds i have mine set to 500000,720000 all the time it makes it alittle faster i research the coby just about every day
can anyone tell me where to put notification tones and ringtones?
i have it working on the stock
/nand/media/{notifications,ringtones}
Sent from my HT_PAD1051 using Tapatalk
Just wanted to give a quick update on the gallery situation. I still can't make the stock gallery work but... I did get a market app called JustPictures! to work and I could set backgrounds from it. Not a huge milestone but I learned to put a data folder in the update zip and get the apps to flash while I was working on it. And I don't care about gallery not working anymore.
Greetings from Brazil!!!
Worked nicely on my Kyros 7015.
The only thing that does´t worked at all was the calculator.
Wonder if there´s any way to install a PT-BR Language pack..
ok i put the tones where you stated but there still not showing up
l_n - Drop box says "too much traffic on Public account, downloads suspended"
Rasoleum
So can't get patch. Also my Ultra Keyboard doesn't seem to work although I redownloaded it and installed. Best, Rasta
Rasoleum
lol Not funny that you can't get it but funny cause the words getting out there how good this rom is l_n and I guess we overloaded your D box account lol....
Rasoleum
For those not able to download the patch (watery-k-patch.zip) uploaded this mirror: Fileserve: watery-k-patch.zip File size: 1.20 MB
This is the link to the watery-Kyros-ROM v1.2b.zip: Fileserve: watery-kyros-v1.2b.zip File size: 73.26 MB
... sorry for my bad english ... :cool:
Thanks for reposting those. Anyone wanna donate some file space?
Thanks. Even though you might end up suspended, too. You might want to put up 1.1 and 1.2a, as well, if you have them.
