Was wondering if anyone is using or has tried Amon Ra's Recovery? If so, how did you flash it? Would it be possible to use ROM Manager to do this?
Hello all, new to this but I ended up getting Watery 1.2a installed. I need a little help on getting the browser installed. I pulled the browser from 1.2b and saved it to microSD card then I used AndExplorer to install the browser. The browser works fine untill I reboot then it reverts back to the old browser in 1.2a and I can't use it. What am I doing wrong here?
use rootexplorer to change permissions or just install the watery k patch from the recovery
The patch has been installed, but it doesn't include the browser.apk
Is there anyway using AndExplorer to put the browser.apk on and keep it there?
