Hi
I received my ES777A and i'm going to install it in my car tomorrow.
I was trying the android pad.This evening it restarted around three times. It crashes with most apps then it restart.
Any one had such problem. Is there any solution for it?
Which apps specifically? Mine works fine even with some apps that are not certified for use with the pad.
I've ordered one bluetooth obd week ago
I guess I found out how it works in the near future
When OBD-II Scanner Connected To car And the tablet to main unit
I never worked on android System So I guess that it was fun to learn
Have the option to upgrade android 2.3 system to 4.0 ics & 4.1 jelly bean ?
I understand there is something called Rom ?
Thanks for your help and patience
About app Most important for me is waze
I use it on mi IPhone
I have been told that There is a version for android
Waze is average in my country, search for it on Google Play.
I also ordered a BT OBD only to find out it does not work with the pad. So I use it with my phone and its all good.
If you leave the OBD in the slot, you stand the risk of draining the car battery, use with caution!
Hi Makso,
The bluetooth obd device is available on ebay & the obd app by ian hawkins is available from the google play store, however if i remember right the bluetooth is in the main unit & not the tablet & this is a problem, there is a discussion earlier in this thread where forum members were trying to get it to work with our systems, i cant remember if they managed to get it working so please check before you spend any money on the obd bluetooth adaptor or the obd app.
The android 2.3 system used on our pads is a bit out of date as there are now 2 later versions (4.0 ics & 4.1 jelly bean) now available, that said 2.3 is still running well & is capable of running every app that ive wanted to run so far, so I would say its a bit old but its also a very capable operating system.
Many members have added car friendly apps to improve things, i have added ultimate car dock / filmon / tunein app as well as other navigation apps to customise mine.
Mark
:cool:
The issue I have is that 2.3 is not customised for Tablets so the icons are way too small to press especially when you driving (I know I know, no need to lecture me :p)
I am researching to increase the size of icons. Anyone done anything like that?
Thanks for the response but I have a charger from another tablet
Works well and charges the tablet when it is not charging anything good device does not turn off
The problem is that when connected to a charger then it turns off
Only rec button turns it on again
This same problem was with the original charger
And the device does not reach 100% only 92%
I'm considering sending it back just the tablet
Or wait for the installation of all system a day or two and then see how the tablet responds
So what you're saying it's not possible?
When you say car battery risk ?What do you mean
When the vehicle is in motion?
About Waze is an Israeli software so there is no chance I will not find it in my country lol
hello friends all over the world
As I have written in other mesagi or need firmware for vechio dm7022 ask for help thanks for the link
Hi takuarc,
I have to agree with you ref icon sizes & would love a updated unit, but after being ignored by both winmark and erising im not very likely to shove my hard earned money in their direction ! Both my main units now have broken catches, to rub salt in the wound despite erising ignoring my requests for replacement of the faulty part, they are now advertising the new model with ugraded catch system !
Im looking into a putting together a pad based system that will do most functions (gps music film nav etc) not worried a about dvd & would prefer a hdd or solid state memory solution for films & music in a ripped format, im thinking along the lines of a car radio linked to a pad by bluetooth etc
If you have any joy with the icon sizes please let me know .
Mark:cool:
Hi takuarc,
Mark:cool:
I found an app called WP7 launcher. Testing it out to see what I can do with it :)
Hello friends finally everything is installed and working fine but
I have some problems
When I try to connect the iPhone Bluetooth is asking code Of the device
When I turn on the gps program There are annoying beeps and speech of the gps stuck
Or running too fast
I noticed that the device itself boils From heat
And affects the tablet back
And take time to turn on the device
Sometimes yes and sometimes no
Anyone else having these problems Or similar ???
Thanks for the help
Or running too fast
Thanks for the help
1) The code should show up on your phone, you just need to type it in.
2) What GPS program you using? If you using the stock iGo, there is an issue with speech, just install the new version a few pages back
3) What is the average temp there in Israel currently? Its normal for the tab to heat up to a certain temp but should not go so high as to turn it off or affect performance.
4) I got the same problem with the tab not turning on sometimes, just need undock and dock again. Again, we get what we paid for :p
What show up on my phone This requirement for code :(
I have no idea how Install the new version Very weak in this
We winter in Israel
But it seems he warmed up because it was the first start
At least I hope so
I'm still looking At the beginning of the post In trying to understand Basis
I'm only on page 20 lol: :)mad:
And it's a good time to ask all members
Who have experience Share it with us Take the initiative
And create videos How to root
All the knowledge gained here
Even the list of essential applications was nice
We are fighting in a cheap device always keeping us new problems
So at least the answers should be Hand achievement and ordered
That someone like me that is not strong in English for this example ****ing Challenge
Thanks for the help
Thanks for the help
Hey, take it easy bro. I am sorry to hear that.
I will see if I can upload something.
I am very calm, but this thread is not there a day or two
Someone had to take the initiative long ago
I read all 70 pages and it's tiring And confusing no order
Many links do not work
And when I say fight cheap product
Every day a new problem I think to keep him pinned in the car
For example yesterday the gps worked very well
With software igo
Today after several restorations factory default The igo Disappeared Does not exist from the device along with software that checks the single gps
And when gutters the tablet car and trying with the waze He did not find reception is not even showing Map
And Bluetooth Does not recognize my iPhone And insists on pin bin code
Some Solutions
Bluetooth pin code 00000
waze Not working without WiFi
Two problems I could not solve
Tablet Boiling After 20-30 minutes in the device
Restore software igo
If anyone can copy me his igo folder I would be grateful
mi Email
maksim3@bezeqint.net
One more thing
I saw this video that the guy did exactly what came to My mind
Too bad I do not understand Russian
I understand Main idea except where to hell He Connect wrote the fan
