Is it anything to worry about that 2 of the status messages were:
No /sdcard/.android_secure found. Skipping backup of applications on external storage.
and
No sd-ext found. Skipping backup of sd-ext.
Should I delete CWR now, or leave it for future use? If I don't overclock it, is CWR needed at all?
and
And is it any concern that I don't see a recovery.img file in the Backup directory? (I used ROM Manager and ClockworkMod Recovery, as instructed.)
-Once booted and back to Home screen, open your favorite file browser
-Make you way to your SD card: folder /clockworkmod/backup/(date of backup)
-Check to see if you have files files: boot image, cache image, date image, nandroid check file, and system image.
note: Usually you will also see a recovery.img (image) file, which is the file that holds the backup for the recovery utility itself. You will see this files with most custom ROM packages.
Hi Steve. I did have an SD card in the Nook during the backup (and the resulting backup files are on the SD). I don't have any apps stored on the SD card though; everything's stored internally. Would that explain those 2 messages during backup?
Using ROM Manager to do a backup, wipe partition and wipe Dalvik Cache, I'm stuck at the Advanced and Debugging Menu. Is there a button combo (or something) to get me past this point? Maybe if I let the power run down on its own - it was at 80% when I started. Help, please.
lol, I did.Make sure you read everything in a tutorial.
Are u stuck in recovery menu? Power button will not bring you back to main menu?
Sent from my Droid
Yes, I'm stuck in recovery mode and unfortunately, no, power button doesn't bring me back!
I'm not sure. Make sure u r plugged into charger then hold n and power button to see if it forces a restart.
Sent from my Droid
