newellj79
- Jan 4, 2011
- 87
- 0
It's an android thing I believe and sometimes you can correct the devices accuracy by wiping the battery stats.
Boot to CWR > advance menu > wipe battery stats
Thanks. Will try.
How long do you think it will be, before an Auto-nooter 1.1.0 is available? Thanks guys.
OK here I go again. I just read the whole thread to see if my questions had been answered. Some were, some were not, so here goes:
1 I have an autonooter sd card, can I put all these new files on that one card, including the backup?
2 can you give me some names of file browsers? Can I add any of these w/o turning on Wifi? My NC is rooted and I have not turned on my Wifi for 4 days, just to make sure I don't get that download.
3 After flashing the first 2 files to the SD card, does the NC have to be on or off when I put the SD card back in it?
4 When do you clean up the SD card?
You guys are awesome and very patient, I can't thank you enough for all the help!!!
After doing nandroid backup to sd, can I save these files to hard drive and format sd card in NC?
OK SD card is back in, Astro is installed, now when I try to install ROM file, (pressing ROM, them open app manager) it does not give me Superuser app, but I get a message saying Install blocked: 'Installation of download apks is not supported. ??? Help
