Stelv
- Jan 12, 2011
- 800
- 53
That did it. Thanks and YOU DA MAN! Or, the man sitting next to da man!
Ok good : ) Before u boot into recovery again go into rom manager and flash clockwork recovery again.
Sent from my Droid
lol, I did.that's why I asked if not seeing the recovery.img file was any concern, since I had used the 2 specific processes that were in the directions.
Since you said you usually would see one, and I didn't, I figured I'd ask... (Possibly because it said "Note:" it made it seem possibly important if it were missing...
Thank you for your help!! It updated to 1.1.0 fine, although I did just now experience a couple of freezes, and I just lost my main background page and icons. Only a greyed-out left-facing u-turn arrow button now, and the 6 softkeys on the bottom. Immediately prior to that the main page app icons disappeared and were replaced by 2 B&N book images. Then that disappeared and the greyed-out icons took its place, and the whole thing froze. No response to "n" button. It even ignored the graceful Power Off close request. I had to hold power button down longer to force a shut-down.
And just now got a "Sorry, Activity SoftKeys (in application SoftKeys) is not responding. grrr...
Ok I'm a little bit lost. When I follow those first couple of instructions there, about downloading the Rom manager and the CWR to my sd, am I supposed to do that from my pc, or right on my NC? I kinda need things spelled out for me, sorry. is there anyway I could get a simpler step by step for the beginning there? I am autonootered 1.0.1, and downloaded a ton of apps, and changed my wallpaper, that's about as far as I've gotten with figuring things out. Thanks so much.
The NC doesn't have GPS...it was using your router to figure out your location (at my house in the boonies, doesn't work; at my work, the map puts a pin at the front door)
Another rookie question. Up to this point I have used a 4gig sdcard for everything. Would it be ok to just simply copy everything from the 4gig card to a 8gig card and start using it instead?
Thanks for help with the card. Anybody else have a NC that only charges to 99%. Any ideas on why mine is?
