Did you check the settings? There are many options for customization there.Seemed just like cn7 to me. Back to cm for me.
^ So that means even though I'm on 3.1.1 that I'll have to wipe data (then restore everything) just to flash 3.1.2? That wouldn't be worth it except for a substantial change, such as if they got YouTube working or something like that.
EDIT: Maybe my main point isn't clear. Often devs will give you a clue on incremental updates (i.e. 3.1.1 to 3.1.2) if it can be flashed over the previous version(s) and whether a wipe of any kind is or might be needed. As an example, with Phiremod V4.1, the dev says: "If coming from V4, there is no need to wipe." Incremental updates generally seem to be handled differently than series updates (i.e. V3 to V4 or 3.1 to 3.2). So that's the reason for my having asked because there was no mention by the dev.
@rico2001
Thanks ... and an added question, but first just to be clear. I'm not using RM to flash. Used to always do things via RM on the Droid 1, but then with the Droid X bootstrapper issue, got into the habit of going straight into CWR to do things. Just a bit hazy about eMMC on the Nook and how it all ties together, especially after having read about how some ended up wiping their internal memory and thus unable to boot. Now to my question....
Despite flashing a lot on the D1 and DX, I still feel 'ubber-noob' in terms of NC flashing so thanks for bearing with my questions. Now that I'm running UD 3.1.2 (with just a standard formatted sdcard for working storage), say if I want to switch back and forth between this and Phiremod V4.1, then I need to burn an ext4-compatible sdcard (i.e. bootable CWR mSD v3.0.1.0 ext3 & ext4 compatible) to flash it. But ... what I'm not entirely clear about is once I've done a backup of Phiremod, can I switch back to UD simply by restoring a nandroid (with full wipe) and visa versa?
Does this rom have DSP acceleration enabled? I'm on CM7 and that's the only thing that it is missing IMHO. If it does, then i'll switch asap.
