beta tester. I tried other players, and they worked as well. My experience has not been different than Froyo with regards to movie playing. However, I dont play avi or divx files; I have mp4 files that were re-coded for NC.where did u find that mobiplayer, it's nowhere in the market
Thanks for the tip for clearing out the notifications. I am getting better at clicking that button, though@Tenderidol you can set your cpu to 925. Just use profiles in setcpu and use "ondemand". I have the same problem with clear button, but you can also swipe left to right to clear single notifications.
Mine is set to 925 via UD settings menu. It's been working fine. I must say that browsing the net via Dolphin HD @925 "feels" a lot faster than under Nookie Froyo @ 1.1 GHz. I didn't install SetCPU; I was afraid that it may conflict with the UD settings. So, it's working fine for you? I may install it just to have screen off and battery profiles to extend battery life.Yea I have mine set in menu options as well as in SetCPU. SetCPU may not even be needed. I use setCPU for screen off and battery profiles.
The battery life is not that great compared to Nookie Froyo, but I believe that's the case for CM7 builds, right? It's not an issue for me really...Yea battery isn't great for me either but it is not bad. Also Is anyone having problems with blurry desktop wallpaper?
Battery life is bad for me. about 5-6 hours. Didn't have CM7 long enough to drain it, but seemed like I would have gotten 7-9.
I loaded this on my wife's nc yesterda and set all up for her. I did like the adhoc fix, that was cool. After checking it all out, there were some great features and it ran very smooth. But, its a phone rom patched to work on a nc. Losing the nook app that B&N put on it wasn't great. She has magazine subscriptions that no longer showed up. I ended up going back to autonooter 1.01 with the 1100 OC kernel. I will say that alot of work went into the build and it was /is a nice rom. ButIll wait till a rom is out that is made for the nook if that ever happens.!
Yes the setCPU and UD CPU settings are working fine for me without conflict. SetCPU is not necessarily needed in conjunction with built in overclocking settings though, I just use it for profiles. But I may turn it off and give it a trial run to see how it performs without setCPU. Two processes don't really need to be running that do the same thing.
Battery life will probably be worse on any of these early Gingerbread builds as GB is more memory intensive than Froyo, and has a built into OS task killer that is more agressive than Froyo.
Setcpu is a must IMO for any android version, the power saving you get from profiles alone is worth the hassle of setup.
