TDI_Votex
- Nov 5, 2011
- 32
- 6
...I never got the fix to work on my 2.1 tab. ...
Look at one of my previous post. I included a modified "framework.jar" that correct the GPS speed.
Pretty sure the file is not the same version (OS 2.1 vs 2.3). As you are rooted, get your "framework.jar" file and post it here. I will modify it for the ES777A owner....Secondly the GPS looks to have a software fault mentioned within this thread.. As the speed is almost doubled whatever you actually doing. e.g. youre doing 50 it say 102. its the same whether youre the software is set to mph or kph. I've also tested it side by side with my existing GPS device and that fine so its not a signal issue.
Will the patch linked within this thread fix it for a 2.3.3 version of Android.
