Spacey,
After looking at this further, I don't see any reason why you can't use the 666 recovery image on your 777...
As i understand it there are 2 important partitions:
The BOOT partition allows the unit to boot, and includes the boot loader and android kernel.
The RECOVERY partition is an alternative boot partition that lets you boot the device into a recovery console for performing advanced recovery and maintenance operations on it.
I would imagine that the recovery partitions for the 666 and the 777 are the same. Anyway, if you have corrupted your recovery partition, you have nothing to loose by trying the 666 one, do you ?
You should be able to flash it in ADB by putting the partition onto your sdcard , naming it mtd6.dump and executing the following command:
adb shell flash_image recovery /sdcard /mtd6.dump
Then do a reboot and access recovery by holding the power button and the back button together.
That's my theory anyway…….what do you think ?
Also, would you be kind enough to download your boot partition….I would like to try putting this into my 666 to see what happens………..
The recovery image is not going to work with the es777 because es666 has a 8GB partition vs 4GB partition on the es777
