just can not install it when I go into recovery and install update from sd me aborted. I want to know precisely the actual procedure What '
Can someone help me? I tried to reset to factory settings and now when it goes to the setup screen and I hit the little droid guy it doesn't do anything. I tried reseting again and it does the same thing; the calibration is working and it shows me clicking on the droid but no results. For some reason I am holding the back button and power button and its not going into recovery mode anymore. HELP!
EDIT: I got back into the recovery mode. What should I do? What happens if I apply sdcard:update.zip?
Ya, I was going to try that. I don't think I have the right drivers I'm on windows 7 64-bit and I was reading somewhere that they don't have drivers for FWDN for my version. I guess I could use my windows xp 32 bit laptop for it but where do I even find those drivers? Heh, I was just trying to change my google account for market to the same one I use for my phone and I guess the only way to do that is a factory reset.Same answer to you ....go into FWDN mode and flash the 2.1update....
If you have a problem post again, explaining exactly where in the process you are stuck......
Yes, I followed all your steps and tried it on both xp and windows 7 64bit with the other drivers then uninstalling them, restarting, and installing your drivers. My FWDN doesn't allow me to load the files before hand? Are there any settings you have in FWDN that aren't enabled normally or any steps you might have left out?So...you have loaded the drivers, installed FWDN, and you get that error when trying to connect the tab to FWDN......yes ?
You are doing the three button procedure I previously explained to connect the tab to the p.c. ?
On another thread, someone suggested loading the 3 files into FWDN before trying to connect their tab....you might want to try that.
I hook up the tablet to the computer and start FWDN. I then hold the three buttons and press restart and the error pops upNo settings changed....I don't think I left out any steps.
I've not had the error you are getting.....when exactly do you get it ? Where in the process ?
