You are trying this with the power to the tablet disconnected ?
I found I couldn't get into FWDN mode if the power was plugged in.....don't know why.
I just tried my FWDN and it DOES allow you to load the files before connecting the tablet.I am using win7 32bit and this version of FWDN....
EDIT: Fixed it! It was something to do with the Chinese characters that were in the directory path
got update from manufactures that the 2.3 will be pushed back toward end of december...sorry guys nothing i can do about it
END OF DEC. I think I can wait. at the maintime, any stable 2.2?
2.1 is totally useless.
1) Everything works, I don't know about the Aux in, the Ipod-in works if you have the tablet attached, it also syncs with my droid 3 if I plug it into the powered usb but it doesn't seem to load the library right (I have only tried it once or twice).So how terrible/awesome is this?
I'm considering buying the same radio, either the Winmark, or more likely the Erisin.
I haven't had to root anything since my old Iriver from '04 (which I still love). Before I go nuts though, I have a few questions:
1) How terrible is the radio? If you're just using normal, local radio stations or a CD does it work? How about if you use just an ordinary AUX in?
2) Are the instructions to install it in some form of English? Does the tablet battery last longer than an hour?
3) How terrible is the Android functionality? I mean, I have an HTC Hero that sucks terribly and cannot handle Angry Birds and randomly factory-resets itself ("Welcome to your new phone!"). My needs are low. Can it do Pandora well enough? Does the browser work? Could it play a Youtube video? If I put songs on a microSD can it play them?
4) How terrible is the sound? I'm not looking for thumping bass.
I guess the whole thing sounds too good to be true, so I'm a little terrified.
BTW the rooting process is as simple as installing a program via usb and hitting a button and its zero risk.
