Could the operating system version picture with the 8188 at the end of the number sequence mean that the Realtek 8188 wireless is inside?
Looking for someone with the wifi "error" to give this one a shot. realtekcraig738b.img
Hmm It kind of fixed it. Not getting wifi error and its scanning wifi connections, but it doesnt connect when I try to connect to my wifi. I think it fails on the "obtaining IP part."
Yep it works now thank you so much. There is a tiny problem though. I cant seem to delete the desktop shortcuts. Nothing happens when I try holding down the icon to send it to the trashbin.
I had actually always had that problem with my tablet, it's interesting that it carried over in the ROM. If you go to another screen and place the analog clock widget, then use it to go to alarms, then press the home screen button in the top left, you can then move the icons. Not sure why that works, but see if it will work for you.
Hi, I haven't try the new ROM on my Craig tablet yet, do we have to use the SD version or the RK utility? or it doesn't matter.
Thanks for the great work, I hope that I will get my wifi back, I'm out and my tablet is home, I'm so excited though.
