Hello all. The problem I have not started my car pad DM7033. Need urgently flash or tablet. Help please if there is anyone.
Who can throw off At least one file from the DM7033. The names of the files "build.prop" It is / system /
I turn green car pad is presented after man disappears and becomes a black screen after that, no no no action.
Hi chaz,
Welcome to the forum & thread.
The best deal that i've seen is on ebay (Item number: 230721129384) for £270 UK stock so no customs tax or long wait ! Its a lot less than my wife paid for the older version (& she got stung a extra £30 import tax) the listing on ebay is due to expire today, but no doubt it will be relisted.
Mark
This is where I ordered from, dispatch was directly from UK warehouse without additional taxes.
Was the lowest price I found at the end of December.
Erisin ES777A 3G WiFi Tablet MIDI PAD + HD Car DVD Player [ES777A] - US$330.00 : erisin.com
Hey folks. Newbie looking at one of these....I have some questions:
Is there a reseller in the USA?
When you use the GPS, are you using the GPS through Android or through the unit's windows CE?
Is there a way to play large capacity cards like 16/32gb?
How fast is startup time?
Can you choose your GPS software?
Any chance you can control the FM portion from android?
Hi and welcome,
the GPS is used from Android - so whatever app you are using that utilizes GPS is up to you. The nav software that comes preinstalled is IGO8.
Hoping on testing the large capacity cards myself soon (when they arrive in the post), but should be no problem at least on the Android side.
Startup time for the main unit is very fast, a couple of seconds. Android boot up time is about the usual you would expect from a normal Android phone or tablet.
FM portion is not accessible in the Android - all of the WinCE side features and Android features are totally separate, the PAD basically just has an extra screen input (and touchscreen output) for the WinCE unit.
My video walkthrough is now online with comments! Check the blog in my signature.
Hi Guys, i have just broken my dm7033 tablet and i need your help. I have broken digitizer glass, but lcd screen and plastic cover are OK. If i open the tablet, the front panel of the tablet is a sandwich, containing INNOLUX AT070TN90 LCD screen, glass digitizer and plastic cover with the black border (you actually see this plastic cover on the top of digitizer looking at the face of dm7033 PAD). I am not sure if it is possible to separate the parts and replace only one of them.
Is it possible to separate lcd, digitizer and plastic cover and simply replace only the digitizer part which costs $15-20 or i have to order complete spare front panel from the manufacturer of dm7033 or even complete new dm7033 tablet?
Thank you in advance.
I currently have a 16 gb micro SD card in my 7022 and I haven't noticed any problems with it.
So basically while it's docked it's just running windows CE then?
Yes and no. The WinCE is running in the main unit whether or not the pad is connected. When the pad is connected you can use either WinCE (which has radio, bluetooth, cd/dvd, usb, ipod connectivity, sd) with the pad's screen, or you can use Android which has it's own usb and sd. And of course the android's audio goes to the head unit so if you want you could always just use android and never go into the WinCE part of the device.
But yeah - they're separate.
Hmmm...interesting. This is replacing a pioneer unit so I am hoping for some speed bump. The android part is just gravy and I dont really intend to remove the unit. Is there a USB reader that the pad can access on the head unit? Also, is there a way to mount this flush and if not, is there one with android but it isn't removable?
